Reverse Adjustment Gap??
tttario
Northern Ontario, Canada
Does anyone know the measurements for the reverse adjustment on the threaded rods?
I know the Apex is 27mm on the top and snug up the bottom........
Thanks.
Trev.
in the manual there is no specific measurement..it says to loosen the nut above and below the shift rod...then to turn the shift rod(in the direction where it can be shortened)till there is no play...the turn shift rod back 1/2 turn and tighten jam nuts...i did this and have never had a problem again with reverse..
