Ok I'm sure this has been asked before but how do I stop my 08 ApexGT from beeping when I'm in reverse?
LJ 452
It's been covered many times. Switch is right next to the rev. mechanism, just unplug it, or pull the fuse labeled SIG. What works best is to just cover the beeper with some tape, that way you get a bit of sound to remind you that you left it in reverse. With out the beeper you will remember that you left it in reverse just as your flying over the bars with your feet in the air. You say you won't do that, so did I. Also, tell everyone you ride with not to park behind you, that way when you back in to their sled you can say, "I told you not to park behind me".
Think about it, how much riding do you actually do in reverse.
ApexDriller
Yup, keep it activated, just cover it up with tape or something. Nice to know you "are" in reverse.
dhkr123
Unlike a car, a sled doesn't have a "D" and "R" light on the dashboard, and unlike an ATV, it won't kill your ignition if you hit it too hard in reverse.
I disconnected mine, but used the power wire from the beeper and mounted a bright red led in the dash for a warning light
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
guardrail said:I disconnected mine, but used the power wire from the beeper and mounted a bright red led in the dash for a warning light
Like that!
Yep, that's the ticket.
I like guardrail's idea. Thanks you all who replied.
I have had reverse on my sleds since 95 and none have beeped. I do think a light is a good idea though.
