I was talking to a yamaha mechanic today and from the early reports one of the problems with the apex was that the reverse lever was jamming. To fix loosen the locking nuts on the reverse lever to allow enough play for the lever to engage reverse.
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
NO PROBLEMS WITH MY REVERSE ON MY RTX
paulrxwarrior
no problem here on the attack
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
I noticed the same thing on my RTX.
It feels like its binding.
One of my buds said its ok leave it alone.
HEHE me leave anything alone?
NFL
Not Friggen Likely.
NFL
Not Friggen Likely.
LJ 452
The only thing I've found with my reverse lever is that when I go to engage REV; it doesn't want to slide all the way. So I just put the lever back to forward position give the sled a little gas and it has always fully engages the second time. I seem to have bad luck with the REV. gears lining up. The reverse system on all YAMAHA sleds is light years away from my old 95,96 Polaris which chewed through gears like a shark when it would pop out of REV while backing up. That grinding noise always got everybody's attention were ever you were.
Polaris Reverse
Polaris Reversesnowbelt
- Mar 15, 2005
No problems with mine after 120 miles. I do wish it was selenoid activated though.
paulrxwarrior
snowbelt said:No problems with mine after 120 miles. I do wish it was selenoid activated though.
That would be a nice addition
easylord
If it doesn't engage just grab the bumper and kinda push/pull the sled back and forth alittle. It should go right in.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
It takes very little movement to get the reverse in when it don't line up, I usualy just rock back and fourth a bit with slight presure on the lever and it alway's pop's in.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Mine works sweet and i have 203 miles on it,but my bud who tightened up his track decided to also tighten up his chain in the chain case,well i warned him not to overtighten it,because it will cause the reverse to not engage,it did just what i told him,so just be careful when you rotate your secondary and think that your chain is to loose and needs adjustment,do just a little and try it out by engageing the reverse to see if it still works,if not loosen it back up..
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Same problems occurred when the 03's were brand new.......it's an adjustment thing with the linkage. Doesn't take much for them to get off..... and likelywise, not a hard fix at all.
At least that was my experience.
