wedge
- Jan 15, 2012
- Twin Lakes, WI - Ironwood, MI
- www.statelineadrenaline.com
- 2008 Yamaha Apex GT 40th Anniversary
So I got a deal on one of those billet reverse levers and decided yesterday to try to install it.
I was able to remove the little clips off of the pin that holds the lever in place, however, the pin seems to be a really tight fit. Are there any tips or tricks to changing this out or do I just have to drive that pin thru the hole with a hammer, then drive it back in thru the new one?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
wedge said:So I got a deal on one of those billet reverse levers and decided yesterday to try to install it.
Without actually seeing what you are talking about, I assume you are referring to a split pin?
If that is the case, just use a small drift punch and lightly tap out the pin.
I personally would get a new one for the install as this will likely weaken the old one, or make the hole slightly bigger?
Good luck
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Without looking at it I would guess that you are correct.
wedge
- Jan 15, 2012
Yea, that's what I am talking about. I did not want to force it unless it was like that by design.
I will just do what I was doing then! Thanks guys!
