max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
which year came with when you put in reverse the back shock locks soo you do not suck snow flap into studs??
Never heard of that...which year came with when you put in reverse the back shock locks soo you do not suck snow flap into studs??
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
It was introduced in 2020 with the iACT, they said that when you put sled in reverse the valve on rear shock would close... locking it up soo when backing up in deep snow or off a trailer it wouldnt suck snow flap into studs. i cant figure out what model cus my T cat doesnt lock. wonder if it was only on mountain sleds... but why wouldnt they put on all electronic shock models
I have a 2020 srx. Had no idea.It was introduced in 2020 with the iACT, they said that when you put sled in reverse the valve on rear shock would close... locking it up soo when backing up in deep snow or off a trailer it wouldnt suck snow flap into studs. i cant figure out what model cus my T cat doesnt lock. wonder if it was only on mountain sleds... but why wouldnt they put on all electronic shock models
Pstn head
I believe it was on one of the mountain models
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Mtn sleds don’t have a snow flap tho?
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Or studs
Pstn head
It’s a fox float 3 iqsL found on the cat alpha
canine170
- Jan 21, 2019
- New York
- 2019 SRX LE
First I heard about that.which year came with when you put in reverse the back shock locks soo you do not suck snow flap into studs??
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Sounds like a great idea
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
thanks for replies... i thought the same as when i bought sled i was sure i read it somewhere.... when you hit reverse... the iact closes a valve on rear shock soo suspension stays up allowing you to back off a trailer or into deep snow with no worries of sucking flap in. makes no sense they wouldnt put on most expensive sled in line up.
