Right Side Cover Screw Missing! Grr
Ruggybuggy
Kenora, NWOnt, Canada
Canada
2007 Phazer FX 144
Anyone have a solution for a replacement of the side cover screws on the right side? I have lost another one and there about $8 each from Yamaha. The plastic washer falls off and if the screw loosens it's lost.
10mm is the socket size I was referring to. If you look on that site they have a chart with sizing. Just measure one of the ones you have left.
I lost all of them at least twice. I replaced them with a set from Royal Dist. the first time but the fit wasn't perfect and they were difficult to thread.
I since have gone to tin screws. Remove the rubber washer and re-install it on the screw from the inside. The pitch is perfect for the original Yamaha inserts. And the large flat head acts as a washer from the outside.
Now just keep a 1/4 socket in your tool kit.
I'll give that a shot. I like it because it's cheap! ;)!
Uhm yes for bodywork. Havent been a issue other than digging into the plastic and sharp ends that like to draw Blood.
