riser and extensions
JFonseca
Bristol RI
How much of a riser could you put without extending cables and brake hose? I have a RX-1 short track and am thinking of using mtn cables and hose to do a 5" riser. Any and all input will be helpful.
Justin
I'm not sure with the stock cables. I think a 2" riser would work with the stock cables.
I have a 8" Nytro MTX riser on my RX-1M now and it's WAY up there for boondocking. The only cable I changed to do that was the throttle cable. So, I think the length of the stock throttle cable is you limiting factor.
Good Luck
Frosty
I can't answer your cable extension question. But you can check us (Muffin Works) out for the risers. We have some awesome billet riser kits available that look and work great.
Check out our website for pics and details.
