redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
My dealer, who knows how I ride and the local conditions, recommended a 2-inch riser. I would like to make the seat as well-padded as possible...I am thinking 3" of additional padding. This would get my butt that much higher (being 6'1" on an RX-1 makes you sit LOW with your legs pointing up at a 20 degree angle) and make it easier to stand, and, of course, a more comfortable seat. This should get me up high enough, right?
Or is this wrong?
Will I need a taller windshield?
Or is this wrong?
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
I would try your new setup first to see if you need a taller windshield. Installing a set of handguards like Pro-Tech or Rox would help protect your hands. They are cheap and easy to install yourself.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
4Fighter said:...save your money and stick it out one more season as is instead. I'm 11'-7" tall so I think it would be very hard for me to find the same comfort just by adding a taller seat and taller bars to my '04? I wish I knew what Yamaha had in store for '07 though.
So much for that idea. I just bought an ECP kit, installed a Bender pipe, and stuffed my seat with 4" HD foam and WOW! what a difference in comfort just sitting on the sled. I'm thinking of pursuing the relocated steering column, but I want it to be trailable too.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
redrx1rkt said:...I am thinking 3" of additional padding. This would get my butt that much higher (being 6'1" on an RX-1 makes you sit LOW with your legs pointing up at a 20 degree angle) and make it easier to stand, and, of course, a more comfortable seat. This should get me up high enough, right?
Or is this wrong?
I think 3" would be easier to stuff under the cover than 4" I'm actually 6'6" and 4" it made a world of difference - knees almost level with my hips now.
redrx1rkt said:Will I need a taller windshield?
Look into a windshield extension from Sportech. They slide up and down and can be hidden when not needed. I have one coming.
Phantom
- Apr 2, 2004
How are you stuffing the foam under under seat cover??
How do you re-attach the cover?
Indy
I have the extra tall windshield from Yammie, ugly, but warm.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Phantom said:How are you stuffing the foam under under seat cover??
I did my best to explain what I did here: 2" of foam, very simple. 3" a little tougher. 4" You really have to stretch the cover over the foam, but it worked.
http://www.ty4stroke.com/viewtopic.php?t=15791
rx1wizard
where did you get the 1" riser?
jimmie d
The 2" riser is fine with the stock windshield not any colder at all.
Jim
Jim
rx-1 blue reverse
The top of my hands were colder w/ the 2" riser and the bar rotated fwd. I did 3" of foam to my 03 you problem could not do it yourself. I needed somebody to hold the cover while I stapled it.
p0wd3rp1l0t
just throw a set of handguards on ur bars....keeps 90% of the wind away from ur fingers and hands-cost like $50
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
rx-1 blue reverse said:The top of my hands were colder w/ the 2" riser and the bar rotated fwd. I did 3" of foam to my 03 you problem could not do it yourself. I needed somebody to hold the cover while I stapled it.
I had Sportech's on mine, going to try the Powermad's next.
I did 4" of foam on my '04, by myself. You have to ride it like a surf-board while you stretch and staple it.
- 16K
- 6K
