riser question
I put a Rox adjustable 4"-5 1/2" on my 06 Attak with nothing more than a longer throttle cable. Rerouted the parking brake cable slightly and rotated the brake line at the master cylinder down 1/4 turn. At 6'3" it's perfect while standing in the higher position. I also have a Mountain Mod seat, and when seated the lower position puts my arms at a very comfortable height.
I am just a normal guy (not like viper dave) at 6ft, have the 2 inch rox riser on mine, stock everything and never had a problem with tors.
I put the Apex mountain riser on mine last season. Seemed ok last year. After having the sled in for service this season it started to get a code 84 on full left turn. Rather than screw with moving the cable around I just spent 25.00 and had the Apex Mountain cable installed. Problem solved and now I have enough room if I want to go higher.
i added the 3.5 rox riser on my 06 apex gt, i also purchased the mountain cable but did not need to install it. The stock cable was just fine and I havent had any tors issues.
x2 I'm 6'2" and find it just the right height w/2" ROX riser.
