Blue Me
Guy's how can I stop this annoying control rod slap when having to puts through a no wake zone in the 12" stutters? Anyone know of a bushing or anything??
Bigmax
- Feb 14, 2005
- Portage, Michigan
- www.wilsonshome.com
Somewhere I read where you can take the control rod apart and put an o-ring in there that will help with the metal on metal contact noise. But for some reason I can't find the info anywhere.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I added a thin piece of tire tube to the 'push' side...helped a little, but the best solution has been the right thumb...the thumb helps with bottoming, rod clunks, track harmonics, and hard steering!!!! Just press liberally.
grizzerly
Try softening rebound adjuster, couple notches at a time.
Blue Me
Dude that was hilarious. In all serious stuff though I will be trying to lighten up the rebound also.SumpBuster said:I added a thin piece of tire tube to the 'push' side...helped a little, but the best solution has been the right thumb...the thumb helps with bottoming, rod clunks, track harmonics, and hard steering!!!! Just press liberally.
sniperviper
Yamaha scandinavia offers something called steel-rubber (bushing) to reduce the control rod slap. I have ordered this part and it might be here this week. Its a yamaha part and if you want I can check the part number and post it here when I have it.?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Absolutely post it. I'm game, although the thumb solution is more fun. Just tough in the tight woods.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Maybe I missed something...mine's an 06 rtx..where is the rebound adjuster? I will say when the dial adjust is softer it clunks less, but I thought that affects compression more than rebound.grizzerly said:Try softening rebound adjuster, couple notches at a time.
grizzerly
It controls both. In stutter bumps my experience is to run on soft setting ( 8 of 22) and you eliminate rod slap and ride is better. If too hard shock is not returning and you end up with ridgid ride.
grizzerly
