Room for a 121x15, 1.5" intense track??
alaskanbowtie
Haines, Alaska
I'd like to run this track on my wifes phazer if I get the FX instead of the lite. My concern is the size, those of you who have there sled already or have seen one do you think this will be a problem ?
I looked at a Phazer FX two weeks ago and thought the tunnel was wide enough to fit a 15 wide. Unfortunately, I did not measure the width. I have heard from others that the bulkhead curves inward and limits the sled to a 14 wide. I too want to know for sure. Too bad my dealer is 300 miles away or I'd run over there and measure it.
Heres another pic od Jimmy's sled with the 1.5 track. As you can see it is still the 14 wide one. Im sure it is still better than the 1" stock track
NO not really, I can't see anything from that angle, though it's nice to see LB has a part number for a 14"x121x1.5" track, that would be a great optioj if it came in 128" length.
I took a good look at one in a showroom, and can't see getting a 15" in there ...way to tight.
I will install a Camoplast Freeride 9034C 14"x136"x1,5".
The other option is the Freeride 9033C 14"x121"x1,5". These tracks are specially made for the Phazers.
