Luke600r
- Jan 20, 2015
- Wi
- Yamahas
Hello. Anyone know how much boost the rotrex c15-60 is capable of producing on a nytro.
mpi xtx
One of the guys that I ride with had his as high as 16-17 psi. He has since lowered it to 12-13psi for trail riding.
This is on a 2009 Nytro XTX
Support@MPI
TY Advertiser
- Feb 24, 2015
- Yamaha
We only make pulleys to make about 18lbs for a c15-60 while the unit is capable of more then that it is out of its efficiency at that point. Now take a C30-74 and at the same boost the c30-74 will make more power because of how much more cfm its flowing.
extreman1
Is this a stage one or stage 2 s/c the c15-60??We only make pulleys to make about 18lbs for a c15-60 while the unit is capable of more then that it is out of its efficiency at that point. Now take a C30-74 and at the same boost the c30-74 will make more power because of how much more cfm its flowing.
Support@MPI
TY Advertiser
- Feb 24, 2015
- Yamaha
c15-60 is stage one and YMC 180hp.
extreman1
i have changened pullys so im at 12lbs boost, should i have my gems reflashed and or biger injectors installed? i run race fuel 100% is there ever used bigger blowers avaiable for sale ??Is this a stage one or stage 2 s/c the c15-60??
extreman1
can I take my stage one s/c to 15-18 lbs boost?We only make pulleys to make about 18lbs for a c15-60 while the unit is capable of more then that it is out of its efficiency at that point. Now take a C30-74 and at the same boost the c30-74 will make more power because of how much more cfm its flowing.
