venom
just woundering what rpm you should be seeing on a stage 1 s/c apex mount.with head shim on pump fuel running 26-22 pullies that come with the kit at 6-8000 ft and what hp #'s.also was thinking of turning around my mavrick track because it does not hook up.good idea or not?and would 10500-10800 rpm over speed the compressor at this elevation or is it ok as long as you are only making 10lbs boost.
thanks
thanks
http://www.ty4stroke.com/viewtopic.php?p=302637
Do NOT exceed 150,000rpm...supercharger failure imminent...plus it’s inefficient.
venom
so i guess it 10,000 rpm. thanks
Ahaaa you are paying attention....I appreciate the fact that you made an effort.
Yep....(26-22 pulleys) 9800rpm is what's recommended if it spikes to 10,000rpm once in while it's ok.
DynoTech results confirmed MPIs claim so you'll see about 208hp at 8000ft...if it's set up correctly...cold intake air, fuel, clutching, etc.
http://www.ty4stroke.com/viewtopic.php?t=34035
Don’t waste your time turning the track around, it’s soft for a reason, it’s designed for powder.
If you can’t live with it get a stiff lug Camoplast Challenger or Finger track.
http://www.camoplast.com/powersports/eng/mountain_tracks.html
A
