marpolsdofer
fraolib said:zackn291 said:I'm not worried about loosing hp I'm just worrie about damaging something but from the sounds of it I have nothing to worry about.
i was running 12300 on mine bone stock. it was just the belt put a new belt on and it was fine. 3000mi on belt
My case in point yea in drag race but dont realy need to worry about it if your main focus is top speed. Your gearing ratio does, HP does not win a top speed race RPM does, if you have unlimed track. Why does HP and a torge go down after a certin point not only is it desinged like that, it requiers less amount of force once up to speed. Spin a mary-go-round it takes force to get it to there, but once you get it there you can just keep the speed up by lightly pushing it.
fraolib
k yea makes a little more sence. but im not so sure the phazers are making enough power when there at 12300 or in the 12's to turn the gear. i know when i was running high i was only getting about 73mph
zackn291
Last weekend I seen 90mph on the dream meter
fraolib
my spedo is accurate according to the gps
marpolsdofer
yea you have to clutch for the conditions unforatanly, does no good to be spiinig a track going 12k if you not getting tracktion. You dont really see your topp end much durnig the races, unless there are strait with low to no snow. You do need sufficent force to matine speed, yes. If you drop drimatincly in HP you will loose you speed becaues it n not sustain sufficent force to keep it moving at that speed. Thats why 4st get lost againsts 2st becaues they can putt the power were they need it and them firing everytime. You can evently catch up but it might take a while. I would like to see a high reving engine lie this 4st in a sport bike and see what you can get for top end.
80h4thephaze
blueironranger said:Yes it's too high. 10800-11500 where you want it. Power starts dropping off past 11500 and the rev limiter kicks in at ~12200. What were your rpms on the way up? Perhaps you ran out of gearing but that unlikely at 125kph I would think.
I've seen 12 280-12300 not redlining.
