saltr
- Oct 14, 2014
- RS Venture GT
Hello All; I am considering installing a lower engagement primary clutch spring on my 09 Venture GT. I have seen threads for various products (Schmitt Bros.,Ulmer,Barn of Parts). Also considering a lower preload Yamaha spring with a similar spring rate. To all that have done this mod,what did you like or dislike about the change,and which would you suggest. Thanks for any replies-saltr.
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
Like very
Like very much, no negative for meHello All; I am considering installing a lower engagement primary clutch spring on my 09 Venture GT. I have seen threads for various products (Schmitt Bros.,Ulmer,Barn of Parts). Also considering a lower preload Yamaha spring with a similar spring rate. To all that have done this mod,what did you like or dislike about the change,and which would you suggest. Thanks for any replies-saltr.
chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
I love it...I purchased mine from Ulmer Racing.
saltr
- Oct 14, 2014
- RS Venture GT
Which Spring did you end up using? ThanksLike very
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
I did the spring last fall and find it wonderful. Love the engagement change to a much smoother rate. I purchased mine from Ulmer Racing.
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
Schmidt bros
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Barn of parts spring in my 14 LTX. Love it and no changes in performance, gas mileage or anything else....and at $26 the price is right!
Installed a Schmidt Bros. Comfort Clutch Kit in my 05 Vector two seasons ago. It's OK but expensive ($150?) and for $26 for a spring from Barn of Parts that does the same thing, it's a no brainer.
saltr
- Oct 14, 2014
- RS Venture GT
Thanks All for the replies!
569jason
- Aug 22, 2007
- Fort Wayne,IN
- 2011 RS VENTURE GT
I changed to a Y-P-Y spring in my rs nytro. It dropped engagement from 3600rpm to around 3300rpm. Smoother take offs. Nice upgrade for $24.
MidwestMike
- Sep 14, 2012
- Oak Lawn, IL Ride in SW Michigan
- Vector
I kept hearing you needed to do the rollers and the spring.
I dropped in the Y-P-Y Spring, 90501-581L5-00, left the rollers as is and couldn't be happier. I'll have to double check but I believe I lost more than 300 RPM, I'm thinking it was dropped from 4000 down to ~3300.
saltr
- Oct 14, 2014
- RS Venture GT
I ended up installing a Blue-Pink-Blue Spring at the recommendation of my dealer which has the same pre-load but much less rate than my stock spring.Engagement went from 3300 to 3000, with a little quicker upshift, and wide open shift rpm stayed the same at 8500. Much better sled to ride at slow speeds, especially on and off the trailer.I kept hearing you needed to do the rollers and the spring.
Stonetire
- Oct 14, 2011
- Central New York
- 2010 Vector LTX
I went with the Schmidt Brothers kit and could not be happier. It included the shorter spring (by 1 inch) and the 14.5 mm rollers. The OEM clutch setup had an engagement between 3800 and 4000 rpm. With the new kit the primary is engaging 2500 to 2800 rpm. Yes it dropped about 1000 rpm. This makes slow speed manueverability through tight woodsy sections sooo much nicer. I don't have measured data to support it but the mid range pull also feels stronger from the stock clutch setup. I cannot understand why the clutch does not come setup like this from the factory. I feel it was money well spent and would strongly recommend it.
saltr
- Oct 14, 2014
- RS Venture GT
Sounds like you got an even better result than I did. I may have to consider it. Thanks-saltr
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What is you full shift out RPM? I put in the Spring and rollers and the engagement is very low but my shift out is almost 9000 rpm's and will slowly fall back to @8500. I changed the helix to a 51-43 but that dropped peak rpm to low (7800) out of the hole. I wish I had a strait 45 degree to try vs the stock 43
saltr
- Oct 14, 2014
- RS Venture GT
My wide open throttle shift rpm is 8500, with cleaned and dry lubed clutch weight bolts and rollers. Only change I did was the primary clutch spring to B-P-B. Engagement is at 2900.
