RTX clutching
Rick Chalut
Canada
2009 nytro xtx
I have an 08 rtx. Has a pipe k&n and pc5. Any clutching ideas? Looks like the stock clutching is in the sled right now. Not sure how it works right now, just wondering if anyone has any ideas or tips without breaking the bank. Thanks guys.
Call Chris at schimdt brothers Have used him for the last 4 years .The man knows what he is doing has a lot of setups .
Without breaking the bank, cheapest kit is probably Drag n flys from Supertorquer systems..aka heel clickers...I can give you the black spring set up and guarantee you will be happy...just a primary spring and weights and pulls hard!
How much???
What are the spring rates?
I think bender sells the kit for $240. Not of the black spring...400/140 I think. I just know it worked well
I have been using ulmers clutch kit for the last year years with no problems. It pulls really hard.
You have already put the expensive stuff on. Why cheap out on a clutch kit. Just pull the trigger on a full clutch kit and don't look back. You won't regret and you don't have to spend hours clutch tuning. Just install, run, pull or add a weight or two, and you're done.
How much is the Ulmer kit? What kit should I do?
Ulmer here also. He sells a kit complete,with what you bought so far and the clutch kit to match. Might as well talk to him about your riding style, and what you expect. That way he knows if there should be a gear change also....
