Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
I have an 08 rtx. Has a pipe k&n and pc5. Any clutching ideas? Looks like the stock clutching is in the sled right now. Not sure how it works right now, just wondering if anyone has any ideas or tips without breaking the bank. Thanks guys.
rx1fast
- Dec 12, 2006
Call Chris at schimdt brothers Have used him for the last 4 years .The man knows what he is doing has a lot of setups .
shadow44
Without breaking the bank, cheapest kit is probably Drag n flys from Supertorquer systems..aka heel clickers...I can give you the black spring set up and guarantee you will be happy...just a primary spring and weights and pulls hard!
Nytro Nasty
- Oct 17, 2014
- 2008 Yamaha FX Nytro 136, mountain fit vent kit, oft steering relocate, mountaintech skid plate, simmons flexi skiis with 6 dual runners, skinz front bumper, DDM Tuning HID lights, 55 watt ballasts with 4300k bulbs.
All done in one season.
That's is so far but much more on plate for this year!
How much???Without breaking the bank, cheapest kit is probably Drag n flys from Supertorquer systems..aka heel clickers...I can give you the black spring set up and guarantee you will be happy...just a primary spring and weights and pulls hard!
Nytro Nasty
- Oct 17, 2014
What are the spring rates?
shadow44
I think bender sells the kit for $240. Not of the black spring...400/140 I think. I just know it worked well
rrxx-1
I second the Drag n fly's, great setup!
Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
I have been using ulmers clutch kit for the last year years with no problems. It pulls really hard.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I will second Ulmers kit! I've had the drag n flies and 2 speeds but not even close to overall performance gain and help tuning it from Allen. Ulmers kit 100%
gc_srt
You have already put the expensive stuff on. Why cheap out on a clutch kit. Just pull the trigger on a full clutch kit and don't look back. You won't regret and you don't have to spend hours clutch tuning. Just install, run, pull or add a weight or two, and you're done.
gc_srt
+1 on Ulmer
Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
How much is the Ulmer kit? What kit should I do?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Contact Ulmer and Allen will get you what you need.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Ulmer here also. He sells a kit complete,with what you bought so far and the clutch kit to match. Might as well talk to him about your riding style, and what you expect. That way he knows if there should be a gear change also....
