Dose anybody have good set up for gearing on 06 rtx covered to attack please let no and if I half to change chain length thanks
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
A 23/40 gear ratio works great in the 136" Attak track/skid length. It still would allow you to use your 70L chain so you would just need to pick up the gears. I've run this set up in 136" and 144" track lengths with great results. You get better acceleration and better gas mileage than the stock gears. Unless you're looking for the ultimate in top speed this works out great as an all around gear ratio.
Here's a bit of info for you:
'06 Apex RTX stock set up: 24/38 gears with a 70L chain. Gear ratio: 1.58. Estimated top speed: 116mph
'06 Attack stock set up: 23/38 gears with a 70L chain. Gear ratio: 1.65. Estimated top speed: 111mph
Recommended 23/40 gear ratio using 70L chain, Gear ratio: 1.74. Estimated top speed: 106mph
Hopefully this helps you out.
snoprof6
- Mar 26, 2007
- Upstate NY
- 20 Indy XCR
16 Zr 6000 LTD
02 Sx Viper
02 Sx Viper
Are those set ups suggested to use with stock clutching?
Attak has a White secondary spring verses your Pink spring.
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
Yes, stock clutch components will work. With a 136" track/skid I would run the white secondary spring that steiner just mentioned wound at 3-3.
rwill2cruz
- Jan 23, 2015
- Sudbury, Ontario
- 08 GT LTX Anniversary
You would think lower gas mileage with the 23/40 gearing?A 23/40 gear ratio works great in the 136" Attak track/skid length. It still would allow you to use your 70L chain so you would just need to pick up the gears. I've run this set up in 136" and 144" track lengths with great results. You get better acceleration and better gas mileage than the stock gears. Unless you're looking for the ultimate in top speed this works out great as an all around gear ratio.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
The clutches are working in a more efficient ratio, closer to 1:1. Also, some motors are tuned to be most efficient in a given operating RPM range.
