gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Sry it so long but I have a 06 apex gt running boards keep flexin I put the muffin works tunnle support on still flex I called a yamaha dealer and ask them and he told me there should be supports under the running boards I look in told him there nothing all I see is my heat exchanger then he said some one mast have to them out is it true there should be support under there or is he lieing trying to get money out of me and how could I make the stronger or could some thing be broke thank you
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
there are really no supports that i know of. The heat exchangers are made with there own support (L shape) that attaches inside the tunnel and then the heat exchanger attaches underneath the running board which can not be removed, they are part of the exchanger itself. Not sure what your dealer is talking about. just check the microfiche of your sled under the "heater hoses"
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Thank you I was thinking they were wrong We're u feet go it move there to so idk if some thing broke or I'm Missing some thingthere are really no supports that i know of. The heat exchangers are made with there own support (L shape) that attaches inside the tunnel and then the heat exchanger attaches underneath the running board which can not be removed, they are part of the exchanger itself. Not sure what your dealer is talking about. just check the microfiche of your sled under the "heater hoses"
sgauthier
- Mar 5, 2009
- 2011 Apex XTX
they are very light and some have cracked. some folks have had the exchanger crack as well from the flexing
