black knight
Any suggestions one fixing a lean situation.
I pulled my plugs couple days ago to see how they where doing and they where all gray. Mostly on the electrode that comes from the side over the top of the main center electrode.
Adjust Co2 settings????
Ive run the sea foam threw almost 2 tanks so i'm hoping everything is clean threw the fuel system.
Any thought appreciated
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Are they that colour just when idling? What colour is the insulator down inside? To check your plugs for any specific throttle setting you need to run the machine at that setting ie 1/2 or full throttle and then hit the kill button, remove the plugs and read them.
KevinS
Grey to light brown is good.
Tan is perfect color.
black knight
Center Electrode is light Tan to Gray. outer electrode is gray/white
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Sounds good to me.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
plugs
The Apex is on the lean side out off the box..mine is a 07 GT and the plugs as been like that since new.Now as 10000.mile and 6000 miles on boost and runs like a top so leave it.The plug are just fine.
Yup leave er b
black knight
cool i have 22,500km on it. its in my shop for a cleaning so if i think of it i will pull a plug and take a pic
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
would the sea foam also clean the plug and wash away some of the color?
