DinoRX1
i have a 03 rx1 am im wondering if the throttle cable and brake line on a 07 apex rtx are compatible with my sled. if so are they long enough to put a big riser on my rx-1. im wondering how long my cable is compared to the apex rtx. also is my choke cable a simple bicycle brake line? any input how to raise my bars? thanks aot
grader
get an 05 rx mountain throttle cable. the choke and brake line can be re-routed to fit.
DinoRX1
that should work for how tall of a riser??
grader
bars on mine are at least 6 inches higher than stock.
DV8
- Feb 9, 2010
- Howard City MI
- Attack and Axys
grader said:get an 05 rx mountain throttle cable. the choke and brake line can be re-routed to fit.
Yep, what he said.
DinoRX1
thanks but where can i find a 05 mtn throttle cable??
DV8
- Feb 9, 2010
- Howard City MI
- Attack and Axys
DinoRX1 said:thanks but where can i find a 05 mtn throttle cable??
Any dealer can order it for you, PORT Yamaha is a site sponsor and can get you everything you need also.
