jets
i will be running 167.5, 170,s this should be realy close for mine. as my bit,s were up in the 185-200 range as i went up from 165 to the drilled bit size the plugs got darker and darker and the radar speeds got slower as the plugs got darker and it was just to crisp with leaner 165,s so i would not hold it to long. it pulled extremly hard but would fall off a couple of hundred rpm on top kind of flaten out. with the 185,s it would just go flat and not pull its peak rpm at all but still plenty fast at 116 117 on the gun but to rich with a dark ring on the outer edge of the plug. not snow white like the 165,s.
