Rx-1 exhaust retrofit
SledDan
Canada
Srx & Rx-1
Will the exhaust pipes and muffler off a apex work on a rx-1
They can work but there are modifications that need to be done as the pipes are different legnth's than the rx ones. Never done it myself but I did read a few threads on this as people order the 03 rx1 y-pipes and put them into their apex as they last longer.
What year rx are you asking about? Just put 03 rx1 silencer with the stainless y pipes already on an 05 rx war. Titanium blend pipe oe was broken in same area 2wice on that sled.
Rx and apex exhaust can be swapped as a set. You can't mix and match headers and mufflers. Flex pipes are same dims between the two engines.
Keep in mind matching exhaust covers and tips are needed for a clean fit.
