RX-1: max lug height with stock 8 tooth drivers
Joa
Sandpoint, ID
How tall of lugs can be run on the RX-1 without hitting using the stock 8-tooth 2.52 pitch driver?
I'm pretty darn sure you can get a 2 1/2" track under there.
I say this because I have a 2 1/2" Camo Extreme under mine with 3.0" pitch 7 tooth drivers. That's 3 x 7 = 21" circumfirence
The 8 tooth x 2.52" = 20.16" circumfirence.
So the 8 tooth drivers are nearly an inch smaller than the 7 tooth 3.0" pitch.
You may have to trim the very outer edges of the lugs (I did with mine with 3.0" pitch 7 tooth).
Other than that and trimming off the little angle/divider running horizontally across the front heat exchanger, you should be good to go.
Frosty
