Helgy
- Jul 16, 2010
- Stewart B.C.
- 03 RX-1 Mountain MCX
My RX-1 MCX had 130 main jets, my new engine came with 135s. I ride from sea level to 6000 ft, which jets should I go with, or is there even enough difference to matter? I could use some suggestions on carb set up, as I am building a set from two full sets, one new, one used. My old engine broke the crank and #1 connecting rod. The new one has had something corrosive run into the one of the carbs and will need some parts swapped, or maybe I will just use the old carbs...
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Do you have an AFR meter?
Run the 135s and let us know what the AFR meter says.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Not a MCX but thought you might be interested.
We run 127.5's on a MPI Supercharged RX 1.
AFR's are plenty Fat.
We have run that at 6 & 12 lbs both .
Sea Level to 1,000 ft
Helgy
- Jul 16, 2010
- Stewart B.C.
The sled has no AFR meter, it ran for 12000km before the engine died an unceremonious death. The sled was used in Prince George BC before I got it, and it did not last long here. It was running 12-13lbs boost, and has a high low boost vacuum switch on the turbo. Which jets would be safer to run since we start riding at sea level? Do I need an AFR meter?
