Looking to get the under the tunnel exit - can you use the stock exhaust and cut off the end/silencer, then run new end pipe to face the track? Is this too loud or are there any other concers? TJ's is out of the one piece kit, looking for something similar. Thanks, D.
A number of us have cut off our pipe at the X-over, then weld a glasspack on to it which can run 12-22" back from the X-over. It sounds great, looses weight, and looks cool. Good luck.
Rt
Edit.....we did this on RX1's, don't know about Apex.
