Helgy
- Jul 16, 2010
- Stewart B.C.
- 03 RX-1 Mountain MCX
So, I tore my RX-1 apart close to 4 years ago, and am just getting it together now. The top vacuum line on the stock fuel pump is missing its hose, can someone help me out and tell me where this hose goes please? My memory fails me...
if no one chimes in, i have an 04 rxwar 1/2 apart in the garage atm. i will look after i get home tonight and post up some pics or at least the location of the fitting.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
From the shop manual, looks like it attaches to a nub on or near the fourth rubber carburetor joint at the engine. Furthest carb from the pump. The other line same area on the first carb joint.
tproteau
- Sep 28, 2014
- Wpg Manitoba
- 2003 Yamaha Rx-1 LE Liquid Silver
1998 Polaris XC 700
2007 Ski-Doo MXZ Adrenaline 800 HO
it goes on the intake boot of either the fourth or first cylinder. Just on where the carbs attach to
Helgy
- Jul 16, 2010
- Stewart B.C.
Guess I should mention the sled has an MCX turbo, I didn't see anything in the installation manual about relocating this hose, so I assumed it would be in the stock position.
might get more answers in the turbo section on hose routing/hook ups. i personally never messed with a turbo sled so i do not know for shure. i would assume stock location unless told different.
if you do not get your answer in the next day or so, i will move the thread to the turbo section for you.
- 7K
