Rx Warrior Gas overflow from carb in airbox side
marcmcg
New-brunswick ,Canada
Hey!! I just clean my carb and yesterday I install everything when i start it it ran fine after 10-15sec the idles come rough and I see there gas spilling from 1 carb the one on my right when sitting on the sled!! What i have to check first?? Stuck float ??jet ?? Please help me !! Thanks
Pull the carbs apart and clean them really good and check all the main jets and floats! My gfs vector started the same this year and was puking gas out like yours. took the carbs apart and found loads of green varnish on everything. The needle and float were stuck.
I just try it back tonight and no more overflow from the carb!!! Maybe the float was stuck and everything fine now!! Thanks for the reply
had the same thing happen to me..the geen could be from bad gas from sitting all summer which will clog up the carbs and the gas will have no ware to go other then out the vent tube... a good cleaning fixed it.
