polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
Hey everyone
I have a 05 RX1 with a 121 Mono skid. I mostly trail ride with some road/field drag racing. I am not a super fast or hard trail rider. When the bumps get big I slow down. We do ride mostly in the U.P. on the trails.
I had the shocks revalved and it does not bottom out any more and rides much better. I am not a big fan of the mono. It rides ok but I can not keep wheels or slides under it. Last year my rails cracked. I had them welded and they are cracked again. I have alse removed my Warm and sand blasted and welded all the cracks.
I have a friend with a 98 SRX with a 136 Viper skid. I think that it would be a Proaction skid. He does not have the quick rods and it does not hook at all, but it seem to ride better than my sled. Also he has a son that he ofter takes two up and the sled never bottoms out. His boy wants to ride with me from time to time and if the bumps are 1 ft of bigger my sled bottoms out.
I know the 136 skid will ride better than a 121, but does a 136 Proaction ride better than I 121 mono or does he just have a good one. I know a Proaction will hook when adjusted with the quick rods. My mono does hook pretty good but I ride with a lot of transfer.
So I am thinking about putting a 136 Proaction under my 05 RX1.
Has any body done this? How much work is it to install?
Does any body think the ride would be that much worse than my mono?
I just know he never has a wheel problem and his slids last a long time. Never looks like he is getting beat up in the bumps.
I guess I could also put a Polaris or Arctic Cat skid under it.
I is a darn shame. The 05 Rx1 is the best sled I have ever had but the skid is really a peace of crap.
Thanks for your advice.
Bruce
Bruce
ahicks
The mono's not bad, but if you're tired of messing with it, I wouldn't jump out of the frying pan into the fire. Find a suspension you know and love, and go with that one. It won't be any more difficult to install....
Traildemon
suspension
I have an 03 RX-1 originally a 121 p/action which I extended to 136 which did improve the ride.I have since installed an 136 mono (out of an 08 Attak) & the ride is MUCH better, with no breakage issues.It even seems to perform better in deep snow. You may want to update your mono, I believe there are stronger later model parts available.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
I have talked to two guys selling Attacks that have no suspension complaints. That might be the way to go.
Not sure why these guys are having no wheel or slide problems. What did Yamaha change?
ahicks
polarisconvert said:I have talked to two guys selling Attacks that have no suspension complaints. That might be the way to go.
I don't know why it might be true, but wondering if the 136 will let the track run with a little less tension on it? A lot of guys are blaming a lot of issues on the fact they must be run so tight.
I think the fact that the '10 sleds have gone to extrovert drivers (allowing less track tension) says a lot. That and the new HD front arms may make a lot of difference regarding reliability issues?
