sleddermb
Does anyone know if the chaincase chain on a 2003 1 ton will fit on a 2006 apex. I was swapping sprockets and realized I need a longer chain, but noticed the 70 link chain for the RX1 (8DW-47587-00-00) is a totally different part number than the newer ones (84890-09070-00) and I haven't seen the RX1 chain to compare.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
They are interchangeable as the sprockets are the same on RX-1 and Apex sleds
sleddermb
Thanks RX. I looked again and realized I wrote down the p/n for the RX1 sprocket, instead of the chain, so it should be all good. I am hoping a 40/23 tooth sprocket setup will work with the 70 link.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
It does.
