RX1 Speedo
99yamahasrx
alberta canada
while driving on my fathers rx1 yesterday a weird noise came out of the drive shaft bearing area on his 03 rx1. it sounded like the bearing failed but after i drove anohter few miles all sounds went away and the speedometer is now reading erratic numbers.....any help would be appreciated
I would take the left panel off and inspect the speedo pick up and gear. The pickup may have come loose and may have been rubbing on the gear. I would inspect the drive bearings to see if they need replacing. How many miles on it? You may want to check your jackshaft bearing and drive chain tension.
