Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
What are you running for jetting at 8000-10000?I'm close here at 1500',maybe a little lean.I have 135 mains 17.5 pilots,and 2.25 on the screws.My wot is high 12's,mid is 13.8-14.1,and idle is 14ish.I was thinking maybe leaving it alone and the elevation would make those numbers good.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
WOT is crazy lean. Go up to 140 mains. Idle is OK, mid is a little lean but will get better with larger mains.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I thouhgt 12.5 at wot was what I was looking for?
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
If you plan on going to 8-10000 ft I would leave it as it is. It will get richer with altitude.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
On pump gaz, I would like 11.5-12 - 1 afr WOT
BB
I have a rx with side mount turbo running 14lbs of boost. Running 110 sonoco with no head shim and the thing rips. 125mains, 17.5pilots airfuel at wot 12.5 altitude 5 -6000ft fuel presssure at 4lbs at idle. Just a quick not, I took out the little filters on the needle and seat out which helped my float bowls and fuel pump keep up with each other and the sled doesnt miss a beat all day, and fuel screw out 2 turns hope I can help?
