Rx1 with zx2 skid feel look high
stomper said:
Take a measurement from the center of the bolt (on the idler wheel just bellow the shock adjustment slot) to the under side of your running board. Use a square placed on the ground so you can get the verticle measurement directly above the idler wheel. I will take a measurement of mine for comparison. It won't be till later afternoon tomorrow though as I will be working till then.
its 10 13/16 inch from the botom radiator fine on the running board.
both bold that attach the skid to the tunnel its 17.5 inch apart also the front bolt on the tunnel its 1 1/16 from the strait piece of aluminum.
ad told me 1/2 inch its too tight for the track. now i have 1 inch look to help a little bit.
thanks stomper.
the skid will be removed tomorow, got the normal size spring, 136 ripsaw2 track, got the 136 extension. will install it when i can figure out the slider problem.
zx 2
this is mine . look high but ride greaat
