RX1 Yooper
Since I can't find an Apex Y pipe, I've been told that you can use an RX1 pipe, and weld an extension on, and it will work. Anyone heard of this?
PeeWee
I've heard the same thing. Does it make sense to change both sides to keep the flow on both sides the same?
stretch
The 05 part numbers are the same and the 04 are the same with - 02 on the end which i'm thinking they are made frome different material..
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
this is very interesting....what are the rx1 Y pipes made out of?....are they NOT TITANIUM?.....
I think someone needs to take one and start making something that will hold up!
Dan
Dan
DC5
03 and 04 are stainless and the 05 is titanium. They will work with approx. a 2" extension welded on. Probably easier to do with the stainless pipes and they will last longer then the titanium.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
did the 03/04s have any of the current breakage issues that our titanium Y pipes have?...if not,why dont we just put them on?...or are they not a direct fit?..
sounds better then installing the same y pipes that will just eventually crack again
dan
dan
stretch
The 05 and 06 have the same part number
8fu 14610 and 8fu14620
stretch
SpartaSXr
- Apr 14, 2004
- Western Michigan
- 69 SL351 - 70 SS396 - 98 V-Max 600 XT - 99 Phazer - 06 Attak
Y pipe
I would like to see the difference in the size of the two pipes, Stainless vs Titanium. Even though the Titanium is lighter is it because the wall thickness is thinner to acomplish the weight savings ?
It seems to me Ford was doing some testing with Titanium on the Focus Exhaust flex pipe and the Stainless was more durable in lab testing. I bet the Titanium has the same tensile strength as Stainless while being much thinner and lighter.
For the minimal weight savings and NO worry exhaust problems its worth looking in to. Unfortunatly I dont have access to a RX-1 Y pipe and my Attak is back together and ready to ride. Good post though !
RX1 Yooper
Y pipe
I've got a used right Y pipe for sale. Good condition with no cracks.
$150
$150
DC5
ROCKERDAN said:did the 03/04s have any of the current breakage issues that our titanium Y pipes have?...if not,why dont we just put them on?...or are they not a direct fit?..
dan
I have not heard of any stainless Y pipe failures except for RX-1's running a rear mount turbo. I ran a bender rear mount at 22lbs for 2 years and my Y pipes are fine. However they need to be extended by approx. 2" to fit on an apex.
DoktorC
stretch said:The 05 and 06 have the same part number
the 06's are an 8FP vs. 8FU for the 05's.
For what it's worth the 03/04's are a direct bolt on for the 05's. I'm just waiting on a flange repair and hopefully I'll be back riding this weekend!
