canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
What track are you running?
shadow44
hognit09 said:Gonna go with either the k&n or hurricane lid mod, prolly the lid mod. Shadow44 how much weight did you have to add to your drag n flys, and were did you add the weight, tryin to get a starting point for my 2-speed weights
I used Turks black spring recipe exactly as he laid it out, I have it if you want it but I don't think you can use it as a starting point for for the 2 speeds....2 totally different animals.
canoehead
- Jan 14, 2011
- NE, Alberta
I'm running black spring and 2 washers in the spur with a stock track, but if you're not heavy enough (250 lbs+) or studded I'd recommend 1 washer or you'll spin out any time you pin it. 2-speeds pull very hard.
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
I'm running 2 washers in flip, but with the hindle I'm prolly gonna have put more on there or in mid or tip. Running 136" track
harveywallbanger
- Jan 5, 2011
- Hayward Wi
- 2011 Yamaha Nytro
would k@n filters with pre filters be better than air box mods
shadow44
harveywallbanger said:would k@n filters with pre filters be better than air box mods
The Hurricane air box mod flows about the same as K&Ns...making similar hp gains. The advantage of the air box mod is it allows for stock fit and finish...therefore the air box sensors does not have to be relocated or zip tied anywhere
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I can't compare the two options but I have used Ulmer racing K&N;s on my Nytro without any issues. There is a weight loss difference with going to K&N filters plus more room with in the engine bay if you ever have to get around it. Loved to hear the loud intake every time throttle body opens up although, some prefer the quiet sound!
BADSLED
- May 13, 2004
- Syracuse, NY
shaddow44 said:hognit09 said:Gonna go with either the k&n or hurricane lid mod, prolly the lid mod. Shadow44 how much weight did you have to add to your drag n flys, and were did you add the weight, tryin to get a starting point for my 2-speed weights
HC BLACK spring is perfect with 2 speed weights for smoothest engagement possible using stock rollers. Simple washer or two in heel with stock secondary and you will be smiling. Found 14.5mm rollers to be too aggressive of shift curve with these weights.
