viperaddict
- Sep 6, 2004
- Alton NH
- 2003 viper w/monoshock and simmons skis
2011 apex SE
Anyone ever try these? Thoughts and reviews?
www.schmidtbrosmotorsports.com
Fast Drive Wheels | SchmidtBrosMotorsports.com
These 9 tooth 2.52″ pitch involute outer drive wheels are for eliminating the sub-standard 2010-up anti ratchet style drive wheels found in the Apex, Nytro and Vector’s with the up-graded larger 30mm axle. The factory anti-ratchet drives are very good … More Info
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Same OEM drivers they had before installing the anti- ratchet drivers.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
It's pretty much a known fact that extroverts scrub speed
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
So this is what they had prior to 2011? I have a 2011se and wondering if there would be any top end or fuel mileage gains to be hadSame OEM drivers they had before installing the anti- ratchet drivers.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Extroverts were std on apex starting in 2010. 2009 is when the apex got the beefier 30mm axle. If you ordered the 09 sprockets they will fit your 11 shaft.So this is what they had prior to 2011? I have a 2011se and wondering if there would be any top end or fuel mileage gains to be had
I thought the 09 shaft was the longer version but the same thickness as 08. The 2010 and up was then thicker.Extroverts were std on apex starting in 2010. 2009 is when the apex got the beefier 30mm axle. If you ordered the 09 sprockets they will fit your 11 shaft.
I could be wrong on this it's been a while.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Yes, these were on the prior years, you might gain very little top end but you may get a slipping on acceleration if track tension isn't kept in spec.So this is what they had prior to 2011? I have a 2011se and wondering if there would be any top end or fuel mileage gains to be had
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
The 09 were bigger diameter & longer with involute drivers,10’ up were same diameter & length but had extrovert drivers, the one I put in my 2003 rx1 mod was from a 2013 & i had it shortened so I didn’t have to use a different outer chaincase cover but got the bigger shaft& extrovert driversI thought the 09 shaft was the longer version but the same thickness as 08. The 2010 and up was then thicker.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
I may be looking at aftermarket drivers as well. I may need to change to the 2.86 pitch drivers so I can change to that new Camso Ice Arrowhead track.Anyone ever try these? Thoughts and reviews?
These 9 tooth 2.52″ pitch involute outer drive wheels are for eliminating the sub-standard 2010-up anti ratchet style drive wheels found in the Apex, Nytro and Vector’s with the up-graded larger 30mm axle. The factory anti-ratchet drives are very good … More Infowww.schmidtbrosmotorsports.com
