Sd-08 , reverse work
joe243
Has anyone here come across the scenario where the sd-08 code comes up going into reverse but the sled goes in and out of gear fine.
It has a new actuator - new chain and gears and seems to operate perfect in reverse and forward.
Thanks ahead of time.
Update **.
Fixed the issue. Sensor on the chain case had come loose , re siliconed the sensor and good to go.
Moderator can delete if not helpful.
