Rx1M5
I was doing some pm on my sled yesterday and noticed the brass fittings going into my front mount turbo gas tank were loose. I had them teflon taped when I installed them but apparently that's not the ticket.Seems like the teflon tape almost dissolved or something. What product are guys using to seal those fittings. I'm thinking a leak can't be a good thing right over the header.
Thanks Rx1M5
Thanks Rx1M5
67 Rat
I used a product from Swagelok called SWAK, should be able to pick it up from any oilfield Instrumentation shop
make sure its not small hairline cracks in the white plastic that the brass threads into
BCBoost
Two very good products to use are: Gasoila or Prodope pipe sealant!!
BC.
BC.
Rx1M5
BCBoost said:Two very good products to use are: Gasoila or Prodope pipe sealant!!
BC.
Any ideas where to buy either of those?
Rx1M5
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
ARP Thread Sealer said:These Teflon® based sealers have a rust and corrosion inhibitor. In aluminum, steel, stainless steel, and plastic, they deliver a flexible, leakproof seal against coolants, water, gasoline, natural gas, and LPG. These sealers will be effective from -30 to 550 degrees F, and have a sealant range of 10,000 psi.
ARP Teflon Sealer is what I used.
BCBoost
Rx1M5 said:BCBoost said:Two very good products to use are: Gasoila or Prodope pipe sealant!!
BC.
Rx1M5
Any Industrial supply outlet like Acklands will sell these products.
BC
whitee
I use gasolia every day plumbing as well as on the weekends wrenching it works very well try your local plumbing supply warehouse
Ted Jannetty
Rx1M5 said:I was doing some pm on my sled yesterday and noticed the brass fittings going into my front mount turbo gas tank were loose. I had them teflon taped when I installed them but apparently that's not the ticket.Seems like the teflon tape almost dissolved or something. What product are guys using to seal those fittings. I'm thinking a leak can't be a good thing right over the header.
Thanks Rx1M5
JB weld works very good for permanent install.
Ted.
FASTSLED
sealer
gasoila is the best or rectorseal but mix it good don't use the teflontape
