Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
My 04 warrior has 5700 miles on it. The Buttons on the Secondary have some obvious wear on them.
How much wear is acceptable and how are they removed and replaced?
Thanks.
Thanks.
LazyBastard
Just make sure that there is no contact between aluminum and aluminum. To replace, separate the clutch, pry out the old ones, and pound in the new ones - they're just pressed in.
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks LB
Are they referred to in the parts catalog as (Shoe Ramp)?
Turk
Tech Advisor
Your best bet is use a small pointy object & pound em out thru the bottom. They have a recessed nipple that sometimes breaks when you try to pry em out. Just a heads up...a nickel plated advantedge helix running a silver secondary spring is a lot easier on the secondary buttons.
Bob Miller
- Apr 19, 2003
- New Milford CT
Dano
