danman62
Has anyone else have the part of the clutch crack ,that holds the slide buttons. All three of mind are cracked. I noticed mind when I was checking my clutch and one of my slide button was broken off.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
that will happen
i lost a tower on my secondary the same way. happens when you do not let the engine braking start 1st before you grab a handful of brake.
danman62
Will the cracks cause the button slides to break off.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
yes
Lonerider
- Feb 26, 2010
- south west mi
- 04 rx1, 05 Warrior 06 Attak-w/yamacharger, 07 Attak-Supercharged, 17 Sidewinder TD power trail
They usually break if you change the secondary spring rate or change the helix, I gave up and bought a roller secondary
