Fullback
I'm putting my RX1 back together with the MPI 136 kit and am having trouble getting the secondary shaft in to the drive chain housing the correct amount. I found that it was incorrect when I went to install the key for the disk brake and there wasn't any room. My secondary is also showing about 1/2" of space between it and the outside bolt. It seems to me that the secondary shaft needs to go to gear side of the sled more. Does this need to be tapped on? Any help would be greatly appreciated. Thanks, Bob
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Bob, you can tap on it lightly with a soft rubber hammer. without the chaincase on the shaft can move once you get everything together and tight it'll be fine.
