fldodge
i`am replacing the speedo. bearing on the front drive shaft but the new bearing had no set screws included with it is this right? i can`t seem to break the old one`s free i tryed spraying with penetrating lube and will let sit a while ,i `ve been trying to find set screws but am having trouble finding them i may have to use my old one so i don`t want to destroy them to get them out any idea`s , thanks are these a metric thread? it seems the only allen wrench that fits them is a 7/64th.???
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
You have to buy the set screw they don't come with the bearing. If I remember right its not a Allen head. I don't know the name of them. You could heat the old bearing up that should help.
DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
I think the name is a torx bit, just be careful when you tighten the set screws because you'll break the bit
DAGE said:I think the name is a torx bit, just be careful when you tighten the set screws because you'll break the bit
YES......and YES......Agree!
Budweiser
Heat them up? If you tossing the bearing anyway it couldn't hurt.
The bit needed is a torx size t15.
Yamahammer485
gouldsjett1 said:The bit needed is a torx size t15.
Beat me to it! Those set screws are difficult to find, at least around here.
badlarry
drive bearing
T-15 or t-20 is the size and I beleive they have red loctite from the factory! heat or buy new ones .
fldodge
set screws
some pen. lube overnight worked like a charm t15 bit turned them right out thanks guys
canadianhunter
The set screw thread size if bearing is US made is likely 1/4"x 28, or if metric 6mm x 1.0 or 1.25 pitch, 5mm x 1.0 or 4 mm x 1.0.
Bearing shops and/or fastener places should have set screw kits that they sell set screws by the each.
