I cant change to the shock mode on my 06 apex gt does anybody have any ideas. Do I have to have the sled running to change the mode. How do you clear codes I Just repaired the speed sensor and drive shaft bearing
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
Switch has to be on then push mode button . should flip from hand heater display to shock? I think sled has to be running to adjust shock.
procedure is in manual and I am at work now or I would post it for you.
MT.man
Check to see if the wire to the shock is broken . If it is you cant adjust it but the icon will come on.
mode
had to take out suspension to repace some parts for bearing replacement. the wire doesnt seem to be broke but i cant even get the mode to change.
langow
99.9% if you can't get into shock mode, either your wire is broke or the shock solenoid is broke. Same thing has happened to dozens of people on this site.
fldodge
friend of mine had same thing last year his shock icon would come up for a second then return to hand or thumb mode turned out his needed a computer ,cross your fingers its only a harness or shock soleniod.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
did you reconnect the wire for the shock neer the chain case?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
codes clear them self if you still have a code you still have a prob.
Super Sled
- Feb 25, 2009
- Summit X
langow said:99.9% if you can't get into shock mode, either your wire is broke or the shock solenoid is broke. Same thing has happened to dozens of people on this site.
Yep. When you turn on the key the shock icon should appear when you press the mode button if the wire is intact. Mine broke all the time. If it severs anywhere enough that current cant get through then the shock icon will disappear. Mine was always a broken wire. I finally had my shock EC wire removed and converted to a top clicker to asjust compression. I recommend it and bjowett is the man to help you if you want it.
- 11K
