Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
Looking for shock/suspension recommendations for a 2012 apex xtx. I find rear really stiff and front could use improvement as well. All stock. 100% groomed trails. Can I get it to ride like or similar to a Sidewinder with the QS3R shocks?
72Gran
- Jan 25, 2009
- 92 Vmax 4
21 Sidewinder LTX GT
98 Venture TF
Star Suspension kit for rear
Go with zero preload on front or level A arms
With this set up ride is as very good especially the rear.
to get mine to ride how i wanted, i put the 09 nitro xtx springs with the hygear spring spacers with the yamaha 4 position blocks for the vipers on setting 4. fixed my stiff ride without doing the star and it works great for me.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
What he said.
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
just did the star upgrade..... nite and day ....star all the way
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Star suspension upgrade, Nytro torsion springs, Hygear spacers, and set all settings on soft. I only weigh 150 lbs, so needed it soft to get rid of the lumber wagon ride. Groomed trail riding it rides awesome and a ski lifting monster.Looking for shock/suspension recommendations for a 2012 apex xtx. I find rear really stiff and front could use improvement as well. All stock. 100% groomed trails. Can I get it to ride like or similar to a Sidewinder with the QS3R shocks?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I am really wanting to try the Team FAST air shocks on the front skis. They are super cheap at $700/pair and look to ride incredible, just not a ton of info out there on them. Not sure why they are not taking off more..
kinger
- Jan 17, 2005
- Clear Lake, IA
Another option is you can order the YRSS shocks with reservoir from partzilla for less then $900 I think. I can't wait to try them as well!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Viper Dave has them on front of his XTX along with an M20 airwave on rear along with an on board compressor.I am really wanting to try the Team FAST air shocks on the front skis. They are super cheap at $700/pair and look to ride incredible, just not a ton of info out there on them. Not sure why they are not taking off more..
theCATman
- Feb 19, 2007
- WI
- Yamaha
Can you educate me on the spring spacers and what they do?
I too have put the '09 1200nm Nytro XTX torsion springs on both my Apex XTX'S and that alone made a HUGE improvement.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
The OEM are thin and allows spring to not sit correctly, the Hygear are nice thick beefier spacers and allows the springs to hold the coils straighter.Can you educate me on the spring spacers and what they do?
Do you have the Star kit? Uncouples the skid and rides great, also will lift the skis on the throttle.
like 03 RX1-ER-LE said about taking up the space. keeps the springs from twisting and wearing the rail blocks funny.
i got mine to transfer just fine without the star kit when it has traction as i do not use studs.
theCATman
- Feb 19, 2007
- WI
- Yamaha
No, I do not have the star kit, and honestly I don't want it for the very reason of uncoupling. I had an FX Nytro and hated the POS for that very reason, any throttle input it wanted to lift the skis from being uncoupled. Kinda tough to steer with no ski contact.
I want my machine glued to the trail as best as possible. I'm content with how they both ride with the lighter torsions. Just want to know if I'm missing out on something with the spring spacers.
trailanimal
Has any one tried the Hygear Suspension- Dual pressure system for the Fox Float shocks?? Would like to no how much difference they make. Looks like you can get them for front Fox 289.99 and for the rear shock. Allows one to dial in compression and rebound with a larger smooth zone.
kinger
- Jan 17, 2005
- Clear Lake, IA
They are better then nothing, I would say about 25% larger smooth zone. Still wasn’t good enough for me but probably worth the $289.
