Shockwave helix
I mean that you could have tuned your sled better, by figuring out what helix you would need directly, I think when I ran staight 53, that my sled was faster and had better upshift. I ran the multi angle shockwave.
But you can't beat the tunability on this helix. I would reomend it to any mountain rider, but not to a drag racer....
Is there any more info on this helix. I am curious if there are other arms that can be used to give a different profile range. I see this one is a 8 degreee range (66/58). This looks like a good item but you would always be limited to 8 degrees. With various range arms, this would be an amazing item for tuning, or even checking to see what helix you should be using. I am so used to CAT, having about 30 or so helixes, that I would welcome something like this tto check and see exactly what I need before I buy.
thanks in advance
rcb
