mario750
Hi , can anyone recommend shop in Utica area to do engine swap on ‘17 Winder ? Thanks.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Just curious, what happened to the engine?Hi , can anyone recommend shop in Utica area to do engine swap on ‘17 Winder ? Thanks.
mario750
Burnt cylinder from detonation.
**sj**
Excell motorsports
blurred vision
Hurricane performance in Canada. Your dollar goes further, only 2 hrs from Utica and will get it done fast or just rebuild your motor.
Alsim
- Oct 6, 2014
- LTX SE 2018
Sh$t ! Do you have a tune with knock sensor that retarding timing and lowering the boost ?Hurricane performance in Canada. Your dollar goes further, only 2 hrs from Utica and will get it done fast or just rebuild your motor.
mario750
Nope DD flashes don’t offer knock detection/protection, I wish that I have that feature, then maybe I would still have my motor runningSh$t ! Do you have a tune with knock sensor that retarding timing and lowering the boost ?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
WOW if it’s true! But no knock detection I wouldn’t buy, DD racing kinda stopped after they dropped AC and the new 998 came out,this is what’s heard in my parts. There good with the old stuff with racing.
Wonder what kinda fuel were you running?
mario750
I’ve never put in to my sled nothing less then 91 octane - usually ethanol free.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
That really SUCKS, all around! $$
What did you hear or feel when that occurred?
Crossfire12
- Feb 13, 2017
Thinking about it even without a knock light the STOCK system should lower timing, stop boost,and go into limp mode, I had 1100 with DD Racing stuff with no knock light it still protected it self flashing code on dash ,just no bright knock light. If you continued thru after sled retards, keep giving throttle it will blow. Normally you stop shut sled off, it resets and then you go. I had there SLINGSHOT flash. Both motors 998 and 1100 have knock sensors protecting the motor, I had no problems,it will show code.
mario750
No codes no lights flashing on dash , just suddenly losing power with slight vibration felt . And when I’ve stopped motor wasn’t running on all cylinders.
Crossfire12
- Feb 13, 2017
When if you get motor done, see if they can tell what happened, there a lot of things that could cause this.
