Woody255
- Apr 19, 2016
- NW ON
- Vmax4's
Hi all, for the Tcat guys here…can anyone confirm if the belts from 2017-2019 Thundercat/ZR9000’s are interchangeable? The part numbers are different, but I’m not aware of clutching changes between the 17-19 model years….thanks in advance.
Fords4life
- Dec 7, 2021
- South Dakota
They are interchangable, clutchs all the same, i use ultimax 829 some guys use ultimax 827, factory cat belt is 112 i believe.Hi all, for the Tcat guys here…can anyone confirm if the belts from 2017-2019 Thundercat/ZR9000’s are interchangeable? The part numbers are different, but I’m not aware of clutching changes between the 17-19 model years….thanks in advance.
Woody255
- Apr 19, 2016
- NW ON
- Vmax4's
Ok thanks. Any idea why they have different part numbers?
Turboflash
- Mar 18, 2019
- Southern MN
Different part numbers because supposedly the rubber compounds are slightly different. The 627-104 belt is slightly softer than 627-112 but hard to detect in the field.
Also, Timken XS-827 belt (which cross-references to only 2017 TCats) is 45-1/16" x 1.50". The XS-829 belt (2018 & newer TCats) is 44-15/16" x 1.50" (slightly shorter).
I've tried both and prefer 827 because it is softer and grips clutches better.
IMO, XS is the ONLY belt that will stand punishment. Cat belts I could destroy at will. Tried Dayco XTX (way too hard - belt slip). Tried Gates GForce and carbon fiber. NFG! They would shred easily.
Fords4life
- Dec 7, 2021
- South Dakota
I believe it is was diffrant rubber compounds, some say 827 has better grip than 829, i dont know that, have only ran the 829.Ok thanks. Any idea why they have different part numbers?
Woody255
- Apr 19, 2016
- NW ON
- Vmax4's
Thanks Turboflash! On my sidewinder, the XS was the only belts that would survive as well. The Tcat is a new build, and broke the 112 belt in half. I’ve ordered XS829’s, but delivery won’t be in time for Saturday’s race. I’m scrambling for a spare!
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Are either a direct replacement for the stock belts?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Yes, 829 grips better, the other hard compound, one’s slightly longer.
