crippledncrazy
to get some miles on my sled before I put ulmer racing stage two turbo on? I am also getting the meth kit from hurricane racing. Dave at hurricane is putting both ulmers kit on and the meth kit. Going to be set up for ten pounds. I think it will be fine along with both Allen from ulmer racing and Dave @ hurricane. Just wanted to hear what some of you guys had to say? Also with the meth kit do you guys think I could go higher than ten lbs? Maybe 10.5 or maybe 11? I am getting the boost controller and can go up to 14 lbs. Prolly will just stick with the 10 lbs but again just wanted some more insight
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Well you have some of the best guys in the Biz working on it, and with you. What do they say about the inital break in period? I am sure Dave, and Allen will point you in the right direction. They are more of a customer service mind then a pushy salesman mind.
crippledncrazy
Both guys said it would be fine. Just do a few heat cycles, being sure to let it fully cool. I was just seeing what everyone had to say about it. I am going off what they said regardless because I to believe these guys are the best. Just seeing what people had to say that's all
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
The Nytro has chromed cylinders.It's recommended that there is no brake in required.It's not like the iron cylinder when for brake in, the rings needed to cut the tops off the cross hatch
