Zoggan
You guys are the 1049 experts, the Cat guys aren't. This is the inside of the clutch side panel on my 2014 XF7000 Ltd. Should I do anything different with these pieces or leave it as is to get better clutch cooling???
Sent from my SM-N950U using Tapatalk
kyzer
Vents at your knees is an option. I installed them and a lot of heat comes out of them. I ordered the Mo flow ones nice product..
Zoggan
Yeah, I'm just looking at the first step. Just wondering about the side panel itself.Vents at your knees is an option. I installed them and a lot of heat comes out of them. I ordered the Mo flow ones nice product..
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I think just leave them alone they work fine as is. We have rode on more than one occasion in +50F degree temps with zero heat problems with NA and turbo sleds both. Sure things get hot and cutting more holes would allow more cooling but their still going to be hot even with more holes cut in. So are you gaining anything other than more holes in your sled? Maybe maybe not?
viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
Leave them they are designed to pump air into the primary. Remove them and your clutch and belt will run hotter.
I have ran my sled on 50 degree days without clutch or blown belt issues.
Actually still running that belt this year.
Zoggan
That's what it looked like to me too, but I wondered if removing the lower "deflector" and opening that side vent would actually allow hot air out. My son's 2014 ZR7000 did not have that lower plastic piece installed from the factory?????Leave them they are designed to pump air into the primary. Remove them and your clutch and belt will run hotter.
viper strike
- Dec 22, 2016
- belle plaine mn
The side vent Plastics are designed to pump cold air in.That's what it looked like to me too, but I wondered if removing the lower "deflector" and opening that side vent would actually allow hot air out. My son's 2014 ZR7000 did not have that lower plastic piece installed from the factory?????[/QUOTE
Hot air goes out by your foot.
Add the mo flow knee vents to your knee areas and you will have better air flow in and out. Remember the wind factor cold air in and hot air out.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I trimmed the back edge of the two foam panels to a 45* angle on mine. With the cover install on the machine you will notice that the foam covers the thin opening between the panel and the gas tank shroud, the joint where the panel hinges.
viper strike
- Dec 22, 2016
- belle plaine mn
I did the sameI trimmed the back edge of the two foam panels to a 45* angle on mine. With the cover install on the machine you will notice that the foam covers the thin opening between the panel and the gas tank shroud, the joint where the panel hinges.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Works for me!You guys are the 1049 experts, the Cat guys aren't. This is the inside of the clutch side panel on my 2014 XF7000 Ltd. Should I do anything different with these pieces or leave it as is to get better clutch cooling???
Zoggan
Wow, I'm not having any problems with belts or blowing them. (3800 mi) when mine let go. I was just wondering if any changes were made from the factory as far as vent design and/or appendages that were being installed or deleted.Works for me!
Out of curiosity why did you feel you needed to provide that level of venting? Or do you just like the look and figured more is better?
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I wanted to reduce my under-hood temps. There are times when I will run very hard for extended periods without any trail breaks. In addition to some minor issues that seemed to be heat related I noticed that my intake temps were a bit higher than I would like. Cooling down and maintaining airflow to the intake of a turbo is important. With the added horse-power provided by the turbo that was never designed to be there, heat is a factor. without venting your intake from under the hood the turbo will take in heated air from under the hood and become less efficient causing more heat and higher inefficiency.Wow, I'm not having any problems with belts or blowing them. (3800 mi) when mine let go. I was just wondering if any changes were made from the factory as far as vent design and/or appendages that were being installed or deleted.
Our 14' cat 7000 doesn't have the splitter between primary and secondary either on the inner panel. I doubt it does much. They never stuck with that idea on the panels. I always remove the side panel foam. I did more work for venting on my turbo but the 7000 never concerned me as far as needing more venting or air. Never had a belt issue either.
Zoggan
I can see the need with an aftermarket Turbo. Looks pretty tough!I wanted to reduce my under-hood temps. There are times when I will run very hard for extended periods without any trail breaks. In addition to some minor issues that seemed to be heat related I noticed that my intake temps were a bit higher than I would like. Cooling down and maintaining airflow to the intake of a turbo is important. With the added horse-power provided by the turbo that was never designed to be there, heat is a factor. without venting your intake from under the hood the turbo will take in heated air from under the hood and become less efficient causing more heat and higher inefficiency.
Zoggan
Is your 7000 a ZR or XF?Our 14' cat 7000 doesn't have the splitter between primary and secondary either on the inner panel. I doubt it does much. They never stuck with that idea on the panels. I always remove the side panel foam. I did more work for venting on my turbo but the 7000 never concerned me as far as needing more venting or air. Never had a belt issue either.
