SRmissile
- Oct 27, 2016
- Elora, Ontario
- 2018 50th Anniversary Sidewinder 137
2018 5oth SW...
190 Lb rider
Front springs loosened, Compression on 1, Rebound mid way
Skid coil spring setting stock
Limiter Strap setting stock
Skid Shocks...compression at 1, Rear shock rebound not sure
Torsion Spring at 1
Blocks set for most transfer
Bottoms out occasionally on some big holes
Took it out for a rip and noticed that slower speed bumps are handled well. High speed, multiple stutter type bumps the rear skid seems to bounce too much and isn't as plush.
What changes should I make and what should the rear skid rebound be set at?
190 Lb rider
Torsion Spring at 1
